Hello there good people, I was wondering if you guys would advice me on tuners to get (if it is even worth it)
With my TV, I have to use a Shaw HD digital box to get all my channels. If I plug the coax cable directly to the TV, I will get only the "Basic" channels. No HD/No premium.
So if I used a tuner, a digital tuner, would I get ALL the channels on my computer, or just the basic ones?
I'm thinking about getting this:
http://cetoncorp.com/products/infinitv-4-pcie/
Would it work with Shaw Cable? Would something else work?
Thanks.
https://linustechtips.com/topic/30587-tv-tuner-for-shaw-cable/
Shaw Cable does't support TV tuner cards atm... very sad
  • CPU - Intel x79 3820 @ 4.30 Ghz || Motherboard - ASUS Rampage IV Extreme || RAM - 16GB Corsair Dominator 1866 Mhz 4x4 || GPU - EVGA GTX 680 SLI (2x)
  • Case - CM HAF-X || Storage - Corsair SSD 120GB/60GB WD 1TB Black || PSU - Corsair HX1050 || Display(s) - 3x@ 24" 1x Auxillary 19" || Cooling - Corsair H100
Keyboard - Mionix Zibal 60 || Mouse - Logitech G602
https://linustechtips.com/topic/30587-tv-tuner-for-shaw-cable/#findComment-402494
