Running code in EditPlus issues
Go to solution Solved by fizzlesticks,
In EditPlus your command for compiling should have the argument field set to $(FileName) and the initial directory set to $(FileDir)
and in the command for running the file the argument field should be $(FileNameNoExt) and initial directory $(FileDir)
Did you give it a file to compile?
Try something like
javac testFile.java
where test file is the code you want to compile.
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
1474412270.2748842
Thx, I had something else on the one of argument fields.
