so i have a lenovo Y580 laptop with an i5 and gtx660m@1085mhz i have been having some issues with load times in games and transferring files around my computer my hard drive has been de fraged i also have an msata ssd using intel rst as you can see the speed of the drive goes up and down alot is this because of the ssd and i should expect 40MB/s of an internal hard drive it just felt slow any insight would be great
HD Tune Pro: SAMSUNG MZMPC064HBDR Benchmark
Test capacity: full
Read transfer rate
Transfer Rate Minimum : 22.8 MB/s
Transfer Rate Maximum : 348.0 MB/s
Transfer Rate Average : 90.7 MB/s
Access Time           : 21.2 ms
Burst Rate            : 315.2 MB/s
CPU Usage             : 7.3%
https://linustechtips.com/topic/30517-slow-hard-drive-speed/
Did you use the Windows built-in defrag tool? If you did, download defraggler and use it and test agian. the buit-in one isn't that great.
Link: http://www.filehippo.com/download_defraggler
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/30517-slow-hard-drive-speed/#findComment-391264
Also, I depends what hard disk it is, I could go look it up for you, but you have to give me a Device Manager screenshot. But if the drive is a 5400RPM one, the speeds are pretty normal as the speed dramatically decreases along the capacity disc (bottom line with the number of GB in yellow)
Logan's video for more information:
Personal Rig
https://linustechtips.com/topic/30517-slow-hard-drive-speed/#findComment-391301
Don't defrag a SSD, that does nothing to help the SSD and just wears on the NAND, shortening it's life span. Just use Trim, which finds areas on a SSD it could clear and does it to improve performance.
I don't know any trim utilities however, so just find one. (I apologize if my trim definition is wrong, which it probably is knowing myself)
https://linustechtips.com/topic/30517-slow-hard-drive-speed/#findComment-392038
