Hey guys, I recently purchased a chromecast to hook up to my tv but whenever i go to stream to it, the button wont appear on my device. This is odd because it was working just fine before but now as I said, the stream button disappeared.
Brian May is a rocker. He just does it with style.
https://linustechtips.com/topic/304551-chromecast-issue/
Make sure that you have wifi enabled, I've made that mistake a few times.
Also, opening the Chromecast app on your phone does help if it's not detecting.
Give those a try and let me know!
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/304551-chromecast-issue/#findComment-4139099
Do you have two wireless signals? e.g. 2.4 & 5.0? Make sure they are on the same one. Mine wouldn't work unless I had them both on the same frequency since apparently that splits the networks.
It shouldn't, but it did for me.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/304551-chromecast-issue/#findComment-4139100
It doesn't matter, they are networked together. My devices are all on AC, and the CC is on wireless-N, but they all work together.
@Vitalius correction... it SHOULDN'T matter. :P
https://linustechtips.com/topic/304551-chromecast-issue/#findComment-4139113
