RGB LED Lifetime?
Go to solution Solved by W-L,
How long should the led's last in a mouse or keyboard, and how long till they get to their long-term brightness???
If they are regular old 3 or 5mm LED's they can last between 50 000 to 100 000 hours.
And you can't remove the post  a MOD can move it though, this should probably be placed in the Modding Section.
https://linustechtips.com/topic/303979-rgb-led-lifetime/#findComment-4131176
