Hey all. I'm sure there are atleast a few car DIYers in here so i thought i would ask
I have a honda da integra (1990) and it has no central locking, and no power windows.  I plan to add these things as well as hard wiring a dashcam, adding an extra power socket and a small amp and sub in the boot (250w rms).
Now i don't want to run an 8gauge for the amp and sub, then several 16 gauge wires into the engine bay for the central lockimg, power windows, dashcam and power socket So i thought i would just run a massive 4 gauge and distribute it.
My problem is how would distribute this?
I know how to solder wires and will definitely add fuses and relays where i need them so i don't need help there.
msi h77ma g43
i5 3470
Coolermaster hyper 212 evo push+pull
Powercolor 7950 pcs+ @1100 mhz core 1400mhz mem
Coolermaster haf 912 advanced 120mm rear, 200mm top 200mm front
Corsair vengeance 2x4gb 1600 MHZ
Windows 8 64bit
Silverstone essentials 500w ST50F-ES
Samsung dvd drive
2x 250GB Hitachi RAID0
Seagate Barracuda 2tb
LG IPS235p
Razer Blackwidow
Razer Deathadder
https://linustechtips.com/topic/302897-car-accesories-help/
