no Signal!
Go to solution Solved by dragoon20005,
reseat RAM?
check your power connectors on the mobo
hey guys,
so after really debating mac vs pc for my photo editing i final went with building a PC and went all out and bought
intel i7 5820k 3.3ghz
asrock x99 extreme4
crucial ddr4 16g
evga ssc gtx 970
samsung 850 evo 250 ssd
WD black 2tb
and a 27in monitor
well after putting it together im getting no signal... i put my old card in and same thing i tried diffrent PCI slots ever thing that i can think of any help on whats wrong would be amazing!!!
https://linustechtips.com/topic/302851-no-signal/
reseat RAM?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/302851-no-signal/#findComment-4115363
it was my ram thank you so much i just wanted to cry just about now and i could kiss you right now lol  :lol:
ew no thanks
https://linustechtips.com/topic/302851-no-signal/#findComment-4115462
I once spent about 4 hours throwing a hissy fit at my new build why it wouldn't boot had nothing on the screen no beeps (didn't help the mobo didn't have a speaker..)
only to realise I hadn't plugged the 4/6pin cpu cable in the top right of the mobo.. luckily I was the only one around to feel my shame and embarrassment
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/302851-no-signal/#findComment-4116379
