Hello, recently ive been looking into improving my gaming rig im looking to be buying these:
http://www.scan.co.uk/products/2gb-evga-gtx-960-superclocked-itx-28nm-pcie-30-7010mhz-gddr5-gpu-1216mhz-boost-1279mhz-cores-1024-dp
http://www.scan.co.uk/products/intel-intel-core-i5-4440-s-1150-haswell-quad-core-31ghz-33ghz-turbo-1100mhz-gpu-31x-ratio-84w-retail
http://www.amazon.co.uk/dp/B00N9399TS/?tag=pcp0f-21#productDetails
Im not too sure on the motherboard if anyone has any other suggestions with USB 3.0 that would be great also not too sure about the GPU, open to all suggestions
Thanks
Matt :)
https://linustechtips.com/topic/302428-pc-part-help/
Thanks
Matt :)
Use pcpartpicker and post the results...much easier for you to get a response.
Also please read how to post here: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/?p=39461
https://linustechtips.com/topic/302428-pc-part-help/#findComment-4111258
