I have a gtx 750 ti in my rig and I only managed a very conservative oc with it, however, I did so without increasing the voltage to it.  Even under max load the card never goes over 51 degrees celcius so as long as my temps stay within a safe range will increasing voltage hurt my card at all?
https://linustechtips.com/topic/301912-gpu-overclocking-and-voltage/
Some people argue that high voltages kill a card anyways.
Im on the camp that if your temps are low you will be fine.
Here you go, old school Linus:
