HD not detected
Go to solution Solved by HirgaLTTki,
Hello to everyone,
I recently build a pc with a P8Z77-VLX2 motherboard and added an SSD and a 1TB hdd. The SSD is correctly detected and my OS is installed in it. However the normal hard drive is not showing, even in the BIOS. I tried changing the slot in the motherboard, with no luck.
The drive clearly turn on, you can tell by touching it. I even tried putting my dvd-writter in the same slot and it worked just fine. The funny thing is that i installed a program called PC-Wizard that detects the hardware in your computer, and it's shown there   :huh:
Needless to say I installed all the drivers in the motherboard.
Thank you in advance, and sorry for my english (it's not my primary language)   ;)
Hope that this helps you set it up
Hello to everyone,
https://linustechtips.com/topic/30178-hd-not-detected/
Hello to everyone,
RAWR signature became a bunch of HTML codes
https://linustechtips.com/topic/30178-hd-not-detected/#findComment-385878
Hey there,
Welcome to the forums!
Do you have another machine available for testing if the drive is ok?
You might also be interested in this thread, which is currently ongoing.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/30178-hd-not-detected/#findComment-385881
Man that was quick!
Solved, I knew Linus had the answer  :P  It's my first build and I'm still a little bit lost.
Thank you very much!
No problem! Make use of this forum as much as you can, this is what the forums are for  :)
https://linustechtips.com/topic/30178-hd-not-detected/#findComment-385902
