hello i am looking at replacing my 22inch tv that i have been using for my xbox 360 and pc for the last five plus years as it is on its last legs. i have been looking at getting an LG ultrawide one.
so
1. what is the difference between the LG  29UB65 and the LG 29UM65
​2. would you recommend either of the 2 aforementioned displays or another option (my budget is £250 or less and i wont be buying until my birthday in july so prices will have dropped by then, hopefully )
thanks for the help.
https://linustechtips.com/topic/301770-difference-between-lg-monitors/
Really, it's just the stands. Go with what you think looks and does best.
Just the stand. The UM has a two position, ugly, pain-in-the-ass stand, while the UB has a height adjustable and rotatable stand.
They go for about the same amount, but it seems like the UM goes on sale more often.
FYI I have the 29UB65, and I dig it.
I have 3x of the UB, 2 at work and one at home, and I love them.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
