Html float left problem
Go to solution Solved by Milktealol,
I would think the original image size shouldn't matter if it's being re-sized by css later. But you can try it if you want.
I solved it already!
The problem is because of the different sizing in the image itself.. basic error I made.
I also thought that editing the size in the css would resize it but for my case now, that is where the problem lies.
Thanks a lot for helping me!:)
Hi, I'm having a problem whereby the 2nd row image is pushed down. Can anyone help me? Thanks!
Here is my css.
    #homeposter
        width:100%;
        height: 100%;
        overflow: hidden;
    #HomePoster > img
        width:25%;
        height:50%;
        float:left;
        display: block;
        position: relative;
Here is my coding
<div id="HomePoster">
    <img src="../media/MoviePoster/Annabelle.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/Annabelle.jpg';"onmouseout="this.src='../media/MoviePoster/Annabelle.jpg';"/>
    <img src="../media/MoviePoster/Taken3.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/Taken3.jpg';"onmouseout="this.src='../media/MoviePoster/Taken3.jpg';"/>
    <img src="../media/MoviePoster/BigHero6.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/BigHero6.jpg';"onmouseout="this.src='../media/MoviePoster/BigHero6.jpg';"/>
    <img src="../media/MoviePoster/gonegirl.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/gonegirl.jpg';"onmouseout="this.src='../media/MoviePoster/gonegirl.jpg';"/>
    <img src="../media/MoviePoster/Nightcrawler.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/Nightcrawler.jpg';"onmouseout="this.src='../media/MoviePoster/Nightcrawler.jpg';"/>
    <img src="../media/MoviePoster/still_alice.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/still_alice.jpg';"onmouseout="this.src='../media/MoviePoster/still_alice.jpg';"/>
    <img src="../media/MoviePoster/TheBoyWhoSmellsLikeFish.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/TheBoyWhoSmellsLikeFish.jpg';"onmouseout="this.src='../media/MoviePoster/TheBoyWhoSmellsLikeFish.jpg';"/>
    <img src="../media/MoviePoster/TheInterview2014.jpg" alt="" onmouseover="this.src='../media/MoviePoster/moviedited/TheInterview2014.jpg';"onmouseout="this.src='../media/MoviePoster/TheInterview2014.jpg';"/>
    </div>
I attached the image below.
Thanks in advance!
https://linustechtips.com/topic/301743-html-float-left-problem/
Make sure there's enough room for it. For example if imgA is to go next to imgB they should be sized imgA.width=30% and imgB.width=70%. If one is too wide to allow the other to be next to it then it will be shifted down.
I made the width of that div to be 100%.
The img will be 25% each. So 4 pictures will be there.
But for the 2nd row, only one picture appeared and 3 others have been pushed down to the 3rd row.
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4100559
Does the div have any borders or padding on it? Cause that could actually make the inner space smaller and even 1 pixel can mess things up. Change the individual pictures to 24% and see what happens.
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4100594
Nope, no borders or paddings. I also tried making it 24% but it didn't work also.
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4101001
Interesting... Is there more code than what you shared? Because I copied what you have up top and it's working for me.
The other codes has nothing to do with it. The only thing is i made my whole page into 3 columns, nav(20%) content(64%) and advertisement(16%). But the problem should not be related because of the parent child container. I will try to see if the image size itself is the problem.
Do you think that maybe the problem?
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4101064
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4101119
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4101268
Thanks a lot for helping me! :)
Awesome glad you got it fixed!
https://linustechtips.com/topic/301743-html-float-left-problem/#findComment-4101277
