What do you mean work well?
It's just a plain splitter -- theres not much that could not work well.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/301487-do-these-work-very-well/#findComment-4097140
I think I actually have one in my system, it is fine.
This
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/301487-do-these-work-very-well/#findComment-4097148
Would they work for Corsair fans?
yes.
Just make sure to get a PWM fan hub if you have PWM fans.
PSU Tier List | CoC
https://linustechtips.com/topic/301487-do-these-work-very-well/#findComment-4097150
Why would they do that?
Fans attached directly to the power supply's rail will run at full speed. You need a resistor to lower the speed. if you plug the fan into a motherboard header with DC control, then you can start doing adjusting, but fans undervolt better with PWM.
https://linustechtips.com/topic/301487-do-these-work-very-well/#findComment-4097649
Cables from your power supply will always supply a certain amount of voltage, and Molex and SATA always supplies 12v. 12v is the maximum all fans on the market can take, which will result in them running at full speed. Your motherboard controls voltages delivered to the fans, and all components (like SSD's and HDD's) directly attached to the PSU can control the voltage themselves as well. Fans however are made so that they can be driven by how much volt they get, and can not decide for themselves how much they need.
And trust me, Corsair fans are among those that you don't want running at full speed.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
https://linustechtips.com/topic/301487-do-these-work-very-well/#findComment-4097957
True that!
Frooooooooooooooooooooooooooooooooooooooooooooooooo
i can even hear my AF140L on 20% (around 450 rpm)
gonna replace them with SILENT WINGS 2
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/301487-do-these-work-very-well/#findComment-4100407
