Hello, I am working on my latest build.  It is going to be a White based build. Thank you for checking it out.
System:
Case: Phanteks Enthoo Luxe White (Customized)
CPU: Intel Core i7 4790k
Motherboard: EVGA Z97 Classified
Ram: Corsair Dominator Platinum 16GB DDR3 2400 with light bar kit (Customized)
Graphics Cards: Galax GTX 980 Hall of Fame SLi
Power Supply: Corsair AX 1200i
SSD: Intel 730 480GB x 4 Raid 0
HDD: Western Digital 3TB Black
Sound Card: Creative Labs Sound Blaster Z (Customized)
CPU Cooler: Intel All-in-One Liquid Cooler (Customized)
Fans: BitFenix Spectre Pro Blue LED fans
Optical Drive: Asus CD/DVD-RW (Stealthed)
Monitor: Asus ROG Swift PG278Q
Keyboard: Ducky Legend
Mouse: Steel Series Sensei
IronHide v-4.0 - Current: 2700k (@5.0ghz), MSI Z77 GD65, G.Skill 16GB DDR3 2133, EVGA GTX 670 FTW SLI, Asus Xonar DX 7.1, Kingston ssDNow 240GB Raid 0 SSD, WD Black 2TB Raid 0, Corsair Gold AX 1200, Corsair 800D (Customized), Custom watercooling loop.
SnoBot - In Progress: 4790k, EVGA Z97 Classified, Corsair Dominator Platinum 16GB DDR3 2400, Galax GTX 980 HOF SLi, Creative Sound Blaster Z (Customized), Intel 730 480GB x 4 Raid 0, WD Black 3TB, Corsair AX 1200i, Phanteks Enthoo Luxe White (Customized), Custom Intel All-in-One Liquid Cooler,
https://linustechtips.com/topic/301483-project-snobot/
Wow, the first pic is a potato pic. But excited honestly.
https://linustechtips.com/topic/301483-project-snobot/#findComment-4097090
Yeah, sorry about the first Pic.  Bad phone pic.  I will use my actual camera during the build.
https://linustechtips.com/topic/301483-project-snobot/#findComment-4097096
Good luck. When are you gonna start building?
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
https://linustechtips.com/topic/301483-project-snobot/#findComment-4097156
This build is not a "Budget" system, but the wife approved it, so it will come to be...lol  I ordered the Hall of Fames straight from Galax.  I start building tomorrow.  Can't wait to see how it is.
https://linustechtips.com/topic/301483-project-snobot/#findComment-4097179
Thank you! Yeah, I will post update pictures tomorrow after the build.  Will also update after I am done with the overclocks.
https://linustechtips.com/topic/301483-project-snobot/#findComment-4097200
  • 2 weeks later...
Update:
All parts are in and have been tested to work. Will be posting pics over the next couple of days for the custom touches and overall build.
https://linustechtips.com/topic/301483-project-snobot/#findComment-4196467
