Hi guys n' gals, i'm in need of some help/advice!
I'm looking to upgrade my pc, I had purchased a pre-built gaming pc (which was okay at the time) and is now extremely dated. I'm in need of new parts.
let me give you my specs before I go any further.
(not 100% sure on the brands of all parts)
2TB HDD (Seagate)
16GB Ram (DDR3)
AMD Radeon 6670 GPU (2GB DDR3)
Windowsicon1.png 8 64bit
450W PSU (STOCK)
VIBOX Gaming Case
Gigabyte 78LMT-USB3 Motherboard
AMD FX6300 6 CORE CPU (STOCK SPEEDS)
I'm playing on a 60Hz BENQ 1920x1080p monitor.
I would love to just replace my GPU since gaming is my main reason for buying a PC in the first place, however it turns out my pc GPU is so under powered that its getting its power straight from the PCI-E slot in the motherboard! my PSU doesn't even have a 6 or 8 pin connector to power a GPU!.
So basically I want a good powerful GPU that isn't crazy expensive and can give me a constant 60fps at 1080p. (and wont be bottlenecked by my FX6300)
I obviously need a new good power PSU too, to power the card and the rest of my PC.
Any help/suggestions would be Greatly appreciated!.
Thank you.
Jonny
https://linustechtips.com/topic/301210-gpu-help/
i'm gonna be getting a new PSU anyway probably a 750W, so 270x seems a little under powered? and since my current psu  dosent have connections for a GPU i'll have to
I just recently upgraded my computer and got a 750W PSU and sapphire Dual-X R9 280 3GB and it works like a beast. Haven't gamed on 1080p yet, but if you are worried to not get 60fps 1080p. I would look for a variant of the 280 or 280x.
Overkill Chill:
CPU: Intel® Core™ i5-3450 CPU with Hyper 212evo | RAM:  2 x 4 GB DDR3 MoBo: ASRock H61M-DGS R2.0 | PSU: Rosewill PHOTON 750W | GPU: SAPPHIRE DUAL-X R9 280 3GB | Case: Antec One Gaming | Storage: Kingston HyperX 120gb, Seagate 2 TB | OS: Windows 10 | Displays:  Asus VS228H-P, Hp 2009m
https://linustechtips.com/topic/301210-gpu-help/#findComment-4093809
