so my screens keep changing order according to windows and nv control panel it also happened when i had an amd card. basically the screens are all in the right order but windows thinks they're wrong why is this and this is stopping me from setting up surround the image shows what i mean. im on windows 8.1 pro and latest NV drivers
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/300603-screens-keep-changing/
If you mean that they aren't in order of 123 from left to right, it's because you have them plugged in to the "wrong" outputs on the card. Generally speaking, the HDMI/ DP port will be #1 and the DVI ports will be 2 and 3.
but i have it pluged in with HDMI DP and DVI how will it work then?
PC PART PICKER
https://linustechtips.com/topic/300603-screens-keep-changing/#findComment-4084118
