Hello,
I am currently going through my HDD and deleting everything I don't need.
When I go into my documents, I have loads of game folders such as "2K Games" and "Arma 2 OA" ect.
Is there anyway I can stop this from happening?
Thanks in advance,
- Harry
It seems impossible until it's done.
https://linustechtips.com/topic/300497-storage-issues/
I assume you installed the games via steam? If so you go into steam and select the game, and delete it, if the files still remain, then you should then be able to fully delete them. Hope this helps!
Downloading programs from CNet is not a good idea, as they will commonly include unwanted, and sometimes dangerous bloatware... The more you know.
https://linustechtips.com/topic/300497-storage-issues/#findComment-4082238
Yep they generally contain game saves, settings and other bits, they shouldn't contain a lot of data unless you load in mods and bits. This is just a byproduct of playing games there's no way to stop it as it's how the games are programmed. (Unless you've uninstalled the games and don't plan on installing them again)
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/300497-storage-issues/#findComment-4082263
But I want to keep the games installed but not have the files in that location :(
https://linustechtips.com/topic/300497-storage-issues/#findComment-4082362
Unfortunately you can't do that, without redirecting those folders, which is a lot of hastle. You could look up mkdir online, but you can mess things up with it if not used correctly.
How much space do those folders take up?
https://linustechtips.com/topic/300497-storage-issues/#findComment-4082614
I'm not bothered about the amount of storage they need, I'm just bothered about where the game puts them :(
https://linustechtips.com/topic/300497-storage-issues/#findComment-4082627
Well, you could see online about those individual games, if the have some settings you could change to change the folder they use to store things but most games wouldn't include that by default, and you are likely to run into this issue with each game you install.
Unless someone knows something I don't.
https://linustechtips.com/topic/300497-storage-issues/#findComment-4082687
