Hey there. Some days ago my PC worked perfectly and while I was gaming it just shutdown and the PSU made a little *shwosh" sound. And I couldn't start it again. So I bought a new PSU, installed it and the PC started. However the BIOS was corrupted or something because it had to re-install itself(Dual-BIOS). After that Windows came up and everything seemed normal. So I started Netflix and started watching "Friends"(Cause why not?) while I was casual watching videos on YouTube. But when the next Friends episode was about to start, it couldn't start at all. And the videos on YouTube couldn't start either. So I started Spotify to try the sound their, no success, Spotify actually crashed. Then I tried a local video to see if that worked, nope, it wouldn't start. So I tried a .webm file with no sound, just video. It worked without any problems.
 So I restarted my PC and it wouldn't shutoff completely. So I had to "strangle it do death". When I started it again it worked, for sometime, then the problem came up again. Also while the sound is working, I can shutdown my PC normally.
 I've tried updating the BIOS and sound drivers, I also tried re-installing Windows 8. Nothing worked.
 My setup:
Gigabyte GA-Z68X-UD3H-B3
MSI Ligtning GTX 780
16GB RAM
Samsung 830 SSD
Western Digital 3TB
Intel I7 2600K
I have the Steelseries H Wireless headset(External Soundcard??)
https://linustechtips.com/topic/300351-strange-audio-problem/
For troubleshooting purposes:
-Reinstall sound drivers
-Try another audio-out (dont think this can be it but its worth a shot)
-Go into headphones properties>advanced and change the format
-Check your Start>Computer>Properties>Device Manager for anything that seems out of place
-Might not hurt to do a clean windows install
z0ne
My Rig:
Model: P650RG | Brand: Clevo | CPU: 6700HQ | GPU: 980M | RAM: 16GB KINGSTON HYPER-X DDR4 | SSD: 2x 480GB Kingston KC300 | Screen: 3K Panasonic IPS LED
https://linustechtips.com/topic/300351-strange-audio-problem/#findComment-4079856
z0ne
Already done that. Also went into service.msc to restart "Windows Audio" but it wouldn't start again.
https://linustechtips.com/topic/300351-strange-audio-problem/#findComment-4079913
Did you do all of the above? even a clean install? Because that might point to a hardware problem.
My Rig:
https://linustechtips.com/topic/300351-strange-audio-problem/#findComment-4079924
I'm not sure about the usb part it might be worth a try. But then again applications crashing because of a faulty audio card seems a bit farfetched to me.
My Rig:
https://linustechtips.com/topic/300351-strange-audio-problem/#findComment-4080345
