Water cooling kit advice
Go to solution Solved by CoolaxGaming,
Nice, Thanks for the advice. but can you give me any alternative incase this is not avaiable on my area/region?
Huh any corsair not available? Well any Cooler Master and Corsair pumps are same Aseteke design. So any of them are good.
Hi, Im planning to put in a water cooling device for my FX-8320 because as you all know stock coolers are really loud and AMD Processors are really hot.
   What I need is a 120mm rad (because that is the only rad that will fit to my case), I am currently eyeing on:
Cooler master Seidon 120M Liquid cooling kit
Deepcool Captain 120 AIO Liquid Radiator
any advice on which is better? or should I switch to Air cooling?
https://linustechtips.com/topic/300124-water-cooling-kit-advice/
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/300124-water-cooling-kit-advice/#findComment-4076735
