laptop temp problems
Go to solution Solved by piplupgao,
well it's better now after a re-start probably some weird glitch with fans not going all the way up or something
Is the fan rotating?
https://linustechtips.com/topic/30012-laptop-temp-problems/#findComment-383477
Try changing the TIM. I'd recommend something like NT-H1.
I don't want to risk breaking it by taking out the cpu
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/30012-laptop-temp-problems/#findComment-383485
I replaced the TIM on a laptop without removing the CPU.
https://linustechtips.com/topic/30012-laptop-temp-problems/#findComment-383491
Would you mind opening up your laptop to see the dust levels anyways?
https://linustechtips.com/topic/30012-laptop-temp-problems/#findComment-383506
I derped I meant the cooler
No wonder.
https://linustechtips.com/topic/30012-laptop-temp-problems/#findComment-383572
https://linustechtips.com/topic/30012-laptop-temp-problems/#findComment-383638
