So I uninstalled the drivers for my old gpu and installed my new gtx 960 but when I installed the 960 it won't boot up it detects that there is a gpu in and wants to boot up using gpu. The reason I know this is because my monitor detects a signal but it's just a black screen. How do I boot up to my home screen using the integrated graphics. That way I can install my drivers for my gpu. It's weird because my pc boots up fine without a graphics card but it won't when there is one. My bios doesn't seem to have an option on video except disabling the PCI e lane which than lets me boot up to windows but when I try installing drivers it says there is no device detected. My motherboard is a pegatron 2ab5
https://linustechtips.com/topic/299864-need-help-with-installing-new-cpu-drivers/
To use the onboard you have to plug in the display cable into your motherboard instead of the graphics card
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
PC should start up fine even if theres no drivers or the wrong drivers installed. There might be another issue. What kind of GPU was in there before?
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
