I was wonder if a gigabyte g1 gaming gtx 970 will fit into a corsair carbine 240 with a corsair h100i installed in the front. Pictures would be appreciated as all I can tell is that the g1 fits but not the g1 gaming edition. Also I'm up for suggestions for good gtx 970 that will fit in this setup as I plan on doing sli in the future.
Thanks
https://linustechtips.com/topic/299493-help-build-issue/
None of gigabytes will work. If I were you and I was doing SLI, I would do 2 reference design 970's.  My Strong suite is in GPU so if you have more question please let me know. Also look at this choice here, http://www.evga.com/Products/Product.aspx?pn=04G-P4-3978-KR
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/299493-help-build-issue/#findComment-4067310
