Looking for help on cloud storage solution
Go to solution Solved by Vitalius,
I suggest setting up a FreeNAS box.
It has the functionality of being accessible anywhere in the world over the internet, if you set it up correctly (there are guides, it's very simple).
Lifehacker has a guide to get you started. The FreeNAS forums can get you the rest of the way.
I suggest the Seagate 4TB drive. I have it in my FreeNAS computer now. This computer must always be one but you can reboot/shutdown it via the web interface (so from anywhere at any time). It just can't be booted up.
"Maybe some way to power only the drives, chipset (or whatever part of the Mobo is needed for W/R) and ethernet adapter ?"
That's the entire computer. Seriously. Chipset = Motherboard = CPU (they work together). Drives + ethernet adapter is pretty much all of it. The PSU works to power it, and so is necessary obviously.
FreeNAS works directly from the web interface. You won't need a monitor, keyboard or mouse for managing it. At all.
It has file compression and encryption options.
Yes, it can be accessed with anything that can handle SSH, FTP, or any other form of those, which just about anything can handle them.
FreeNAS, using ZFS rather than UFS (ZFS has more features and is more reliable) needs a lot of RAM (minimum: 8GB).
Anything else you need to know, just ask.
Yeah, will look into that eventually, when I get a working and stable setup. It would be awesome to play anything from videos, music, emulators, browser, ... on my TV. Now if they can only come up with working recent consoles emulators, the PC can prevail once and for all (if that wasn't already clear).
Oh, one thing I didn't mention. I run the emulator on my computer. I just run it from the HDD on the FreeNAS as if it's a HDD in my own computer. In other words, it's not running on the FreeNAS box, it's just "streaming" from it.
My bad. I need to be more specific.
Yes, it just wasn't clear because you didn't specify.  :)
Yep, my bad.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
