Motherboard driver issue
Go to solution Solved by Juan Remes,
Without keyboard and mouse there is not much you can do, i would ensure that just the needed is connected, in other words, disconnect EVERYTHING and just plug in your power cord, mouse, keyboard, and display (remember, USB2.0 is better for compatibility)
If none of that works i would borrow or get a cheap PS2 mouse or KB and make sure the BIOS settings are well set, or you could try another USB KB and Mouse, if that doesnt solve it too then you might have a defective MB
Hello everyone.
-First: I want to say that I'm new to the whole 'Forumworld' so please excuse some errors from my side.
-Second: I'm not a native english speaker ( I speak Swiss German or German), so you might find some spelling mistakes.
THANKS
Now to my problem:
I recently swapped my Mainboard from an Asus Maximus Gene 6 to a Gene 7. (the old one was faulty otherwise the swapp whould be unnecessary)
So I rebuilt my system and bootet up. The mouse and keyboard whould shortly light up and then shut back down again. Bootet into Windows the mouse and keyboard wont work. I thought that the old drivers weren't supporting the USB hubs, but I can't install drivers from the internet nor from the disk that they give you with the board since my mouse and my keyboard aren't working.
I thank in advance for some suggestions ;)
-Fps_ SaVant
My build: CPU: i5 4670k w/ 4.1 Ghz oc / Cooling: Corsair h60 + Arctic Mx-4 / Motherboard: Asus Maximus Gene Vii / RAM: 8gb Corsair Vengeance 1600 Cl9 / GPU: Asus Gtx 770 / Case: Corsair 350d / Storage: 2x Kingston HyperX 3K 240gb (480gb total) / PSU: Corsair Rm750 / Display: Asus VX279Q DP variant / Keyboard: Corsair k70 mx red / Mouse: Razer Naga Hex Wraith red / Sound: HyperX Cloud OS: Win7 Pro 64 bit w/ Win 10 upgrade / + Red Led's
https://linustechtips.com/topic/299337-motherboard-driver-issue/
Welcome to the forum. Also, your English is pretty good.
If you've been trying USB 3 ports, try USB 2. It's generally better for compatibility.
What are your full computer setup specifications?
Thanks! I asked a friend and he also suggested to use the USB 2 ports. So I did but with no results.
I have my whole build in written in my Profile. Do I have to activate something so people can see in my posts?
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4065059
CPU AMD FX-6350 @ 4.5Ghz 1.284v Motherboard ASUS M5A97 R2.0 Memory 4x2GB ADATA XPG Gaming v2.0 1600Mhz CPU Cooler Corsair H100i
GPU MSI 270x HAWK Edition Display HP w1907 Storage 1x Samsung 850 EVO 128Gb SSD 1x 400GB Hitachi HDD Case Corsair 450D PSU Corsair CX750M Semi-modular
Keyboard Logitech G105 Blue LED Version Mouse Microsoft Basic Optical Mouse v2.0 Audio 2x Logitech x230 for a Quad-Channel speaker setup OS Windows 8.1
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4065507
It wasn't there when I wrote the post. That's all I know.
Sig under construction.
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4065628
Going to try that tomorrow. But that whould suck if it was defective. Just got it because I sent my old one back to Asus (audio defective). Well, i thought I could put my ssd into my friends pc and download the driver files over his rig. Whould that work?
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4065739
That is a little problematic, because you could do that and place the driver into your SSD yes, but you cannot install it on your OS. I guess you would be connecting your SSD as a second storage device on another PC uh?, If you run your Windows SSD as a main drive on another PC with different MB/Chipset the OS will detect it and will try to "update" the already installed drivers to the "new" ones and possibly making it worse
I really recommend you to try with another set of pheripherals and try what i wrote above.
Wish you all the lucks and i hope your MB is not defective, that would suck really hard
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4065885
Thanks! I borrowed an old PS2 Mouse from my school. It worked flawlessly! I just need to update the drivers from the cd to new ones, but for now it works.
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4071560
Thats great! I hope everything its ok once you update the drivers, if thats not the case your MB could still be the problem, but that will surely fix it.
https://linustechtips.com/topic/299337-motherboard-driver-issue/#findComment-4074618
