So I played 18 hours of the game, and not had a single crash, but I just started experiencing a crash 30 seconds after the game starts. I tried turning the graphics settings down, I tried verifying the game cache, I tried everything. I would like to avoid re-installing because I have terrible internet speed.
Has anyone had this issue/know a solution I could use. I really want to keep playing ASAP.
My GPU History: GTS 250, 7790, 7850, GTX 660ti, 7870XT, 7970, 280X, 280X Crossfire, 290, 290X, Fury X, 390 Crossfire, Fury Crossfire, 1070, 1080, 1080ti.
My CPU History: Pentium 4, Pentium E5300, Core 2 Quad QX 9650, Intel Xeon 1230 v3, 4790K, 3930K, 5820K, 1700, 3700X.
https://linustechtips.com/topic/299188-massive-dai-issues/
see if disableing the origin overlay helps.
miine got a 50% increase in performance and dosent crash
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/299188-massive-dai-issues/#findComment-4062851
Already had it disabled. I have it off in all games.
https://linustechtips.com/topic/299188-massive-dai-issues/#findComment-4062864
It could be an unstable OC, or something is up with your GPU or RAM.
Run some other memory and GPU intensive game to see if the crashing happens.
Nope, I've been playing AC Unity all week and it's fine. I don't have an overclock, I am running 75Mhz underclocked.
https://linustechtips.com/topic/299188-massive-dai-issues/#findComment-4064065
