Make x or y the subject of one of one equation and substitute it into the other equation, then substitute the value obtained into any one of the equations.
I don't have pen and paper so I can't write it for you. And copying solutions isn't the best way to learn.
Intel Core i5 3570K@4.5GHz | ASRock Z77 Extreme4 | 2*TEAM 8GB DDR3-1600@CL9-9-9-27 | Inno3D GTX 660 HerculeZ 2000s@1200MHz Core 6600MHz Memory | Seagate Barracuda 2TB | Antec Kühler H2O 620 | Antec HCG-620 | CoolerMaster Elite 371
Acer Iconia W700: Intel Core i5 3337U | 4GB DDR3 | 120GB SSD | 11.6" 1080p Display
https://linustechtips.com/topic/297874-help-with-math-problem/#findComment-4043531
Make x or y the subject of one of one equation and substitute it into the other equation, then substitute the value obtained into any one of the equations. I don't have pen and paper so I can't write it for you. And copying solutions isn't the best way to learn.
The problem isn't the technique, I know how to solve these types of problems. But I find it impossible when it's fractions.
I've done other problems like this in the book and I can do them with no problem.
https://linustechtips.com/topic/297874-help-with-math-problem/#findComment-4043564
The first one should be:
x/3 + y/4 = 1/12
4x/12 + 3y/12 = 1/12
4x + 3y = 1
4x = 3y + 1
x = 3y/4 + 1/4
Then use that to find the y in the second and use the y to find x in the first
edit --- ops it's 1 not -1
Shouldn't it be 4x = 1-3y ?
Anyway, the x and y has the same value in both equations.
https://linustechtips.com/topic/297874-help-with-math-problem/#findComment-4043635
x/3 + y/4 = 1/12
12(x/3 + y/4) = 12(1/12)
4x + 3y = 1
x = (1 - 3y)/4 ...(1)
x/2 - y/6 = 2/3
6(x/2 - y/6) = 6(2/3)
3x - y = 4 ...(2)
Substitute (1) into (2)
3((1 - 3y)/4) - y = 4
4*3((1 - 3y)/4) - 4y = 16
3(1 - 3y) - 4y = 16
3 - 9y - 4y = 16
-13y = 16 - 3
y = -1
Substitute y = -1 into (1)
x = (1 - 3(-1))/4 = 1
Edit: ninjaed a few minutes ago
https://linustechtips.com/topic/297874-help-with-math-problem/#findComment-4043652
