Is this a good PC build http://pcpartpicker.com/user/iloveminutemai/saved/6VQhP6 also need help to find a good case.
Hi, and welcome to the forums :D
1) Get a dual channel kit of memory. A 2x4GB kit would be the more preferable.
2) If you don't plan on SLI'ing, drop the PSU to a 500W-600W one.
3) Get a CPU cooler.
4) As for the case, it's really up to the user. Aesthetics is something for the user to decide.
EDIT: If possible, get your OS through G2A. You could save a metric butt-tonne of money buying a product key instead of the full software. In doing so, you could allocate more of your budget into your case or such.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/297559-first-pc-build-help/#findComment-4039368
I'm planing on SLI'ing in the future, and I didn't mean to get a 1x8GB kit I meant to get a 2x8GB kit. What CPU cooler should I get? Thanks for the advise.
https://linustechtips.com/topic/297559-first-pc-build-help/#findComment-4039463
If you plan on SLI'ing, get a 800W+ PSU. As for the cooler, NH-D15 or the Dark rock Pro 3 would be my recommendations. However, depending on your tastes an AIO would be better.
https://linustechtips.com/topic/297559-first-pc-build-help/#findComment-4039476
