I need help ...........
Hi guys i just bought Corsair Graphite 230t
after everything what i can do i did and still not able to figure out how the hell people on youtube managed to do clean cables in this casing .
uploading pic if you bothers have any suggestion about where to put which cable so it may look more clean write it down .
Thanks in advance
post-169269-0-48748700-1422083953_thumb.
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
https://linustechtips.com/topic/297136-i-need-help/
Ever played Tetris?
You're just going to have to stare at it and think for a bit and think about how you're going to run the cables and what cables need to go where in order to come up with something that works and doesn't look like crap.
Once you've found good cable routes, than tie the cables down with cable ties. (The 230T should have little things that you can wrap a cable tie around).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033701
Trial and error. That's it. Take a moment to look at the system and imagine different ways to route the cables. You can physically try different ways as well but either way will work.
That's really all that can be suggested, member of the Illuminati Order,
*your attachment doesn't load. :(
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033737
ALL the cables are pulled to the right side, then brought back one-by-one to where they need to be.  ALL excess cables are then squeezed between the back of the motherboard tray and the right sidepanel.  Set the case with the right-side facing up and attach the right side panel... like squeezing a suitcase closed... sorta.
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033751
Or do good job at managing the cables and watch the panel slide right on with ease.
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033759
Ever played Tetris?
i tried man when its clean a bit cables are so thick on one place so i can't be able to close the back cover.
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033775
Try again; it takes time.
The short gpu and colorful cables aren't helping though :/
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033778
 now its loaded bro. i'm sorry
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033786
plz take a look.
Theres not a whole lot you can do other than trying to put as much excessive cable towards the front of the case where theres no window.
Some of the reasons why it looks so messy is a lack of rubber cable grommets and a non-modular psu. Plus the fact that you can see the whole psu and the wires as it leaves it (and that it's a short psu) doesn't help things.
http://youtu.be/mr4A7HEEBdQ?t=4m7s
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033795
No need to apologize. :)
As for routing your cables better, it really is trial and error. It takes time and patience. Just keep fiddling with the cables until it is better. Although from the image it looks like that might be the best you can do in the front. Except the cables under your HDD, Can't you wire those back some and hide them behind the Motherboard tray? There should be routing "clips" on the back provided by Corsair.
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033797
ill you suggest uncovering the cables and make them flat ? coz round cables are actually the problem as i notice .....
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033800
I don't think that would help too much, but heres an idea:
Try to pull the cables that come out of the psu into the wire management hole at the bottom and immediatley pull it towards the back of the case, and then route the cables around the back panel to make things work.
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033807
i'm thinking to go modular if  in next 10 mints it remains the same .lol
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033814
Rather than doing that, I would try and just make a PSU shroud -- something to cover the whole psu area like on the NZXT H440, S340, or Phanteks Enthoo Pro
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033818
few brain fucks i mean cables are too short to reach the devices ....if i dot this i've tried it :( is there any after market rubbers available for this case for able holes ? or suggest a full modular PSU for system in signature.Thanks .
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033828
You should be able to route the CPU and 24-pin ATX cables like that, no? and gpu/sata cables can be pulled through the back end of the hole and run along the top of the hole (just out of site) rather than through the hole itself.
No, no rubber grommets, but a PSU shroud could make all the difference and give you plenty of space to work with. And a shroud would be pretty easy to make -- cut out a piece of cardboard and see how it works. If it looks nice than paint it or try something nicer than cardboard.
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033838
will you plz give me idea for doing this i have a whole computer lab plus mechanical lab for my guns i have tools to do metal things too.
Any suggestion or picture will be helpful i just need to look at it once.
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033846
Copy that . i'll give it a try . now. Thanks mate . i can buy a 70-100 buck PSU now . if you have any suggestion ?
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033851
You'll want a piece of metal, plexiglass, or cardboard (the latter being a cheap/easy/temporary measure). You'd then want to shape it so it covers the top and sides of the psu area. I.e. it separates the whole top of the case (from the bottom of the motherboard) from the bottom of the case (the psu area).
An EVGA G2 750w is a great choice and about $80~ after MIR. Although, I'd do that last after you try everything else.
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033852
ok EVGA G2 750W. noted . and i'm going to do as you directed .
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033869
You can take everything out (PSU cables) and try to route the larger, thick cables in first and ziptie/cable tie them to the clips on the back, and then take the smaller cables and route them through and if they are too long, gently wrap them around the thicker cables and then route back to the front and plug into the hardware. This is what I did when I had non-modular PSUs and it helped a lot by reducing the length and in turn reducing what is seen up front.
A modular PSU could help, definitely. The EVGA @djdwosk97 suggested is great, and if you are tight on cash, you can get a 550w like the one you have now from XFX for 80$, 60$ after rebate.
https://linustechtips.com/topic/297136-i-need-help/#findComment-4033905
Thanks in advance
Geezus.  That is fine.  Even with the cables coiled in the front, you have great airflow.
Enjoy your PC!
https://linustechtips.com/topic/297136-i-need-help/#findComment-4034368
Enjoy your PC!
It looks pretty bad though since there are wires coming from every direction :unsure:
PSU Tier List | CoC
https://linustechtips.com/topic/297136-i-need-help/#findComment-4036111
