A few questions on graphics cards
1. Can I SLI on a non SLI compatible motherboard (stupid question but yeah)
2. Will my GPU overclock move via PC's, (e.g. I overclocking on PC-1 and move my GPU to another PC, will I need to re overclocking it
3. MSI Afterburner vs EVGA Precision X for a GTX 970
4. How does your warranty work for Overclocking on a EVGA Card
CPU: Intel Core I5 4590 | GPU: EVGA GTX 970 SSC | Mobo: ASRock Fatality H97 Performance | Ram: HyperX Fury 8gb 1866 | SSD: Intel 520 series 240 GB | HDD: WD Blue 1TB | Case: Aerocool DS 200 red/black | Cooler: Coolermaster Hyper 212X | PSU: Antec High Current Gamer 620w | Monitor: AOC i2367fh & old HP | OS: Windowws 7
https://linustechtips.com/topic/296387-graphics-card-questions/
1 you can't sli if the mobo is not certified.
2 you have to overclock it again, its the software that remembers your OC settings not the graphics card, unless you flash the card's bios.
3 either is fine, i use precision X to OC my nvidia cards, and afterburner for Amd.
4 i dont think that evga or anyone can detect that you card died by overclocking.
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/296387-graphics-card-questions/#findComment-4023999
