Seems like it...
Are you running any tasks in the background?
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/295690-dark-rock-3-temps/#findComment-4014295
Load temps?
From info in OP, seems like it could be a bad thermal paste application
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/295690-dark-rock-3-temps/#findComment-4014296
You will want to remount. I idle at around 30-35C in an 80F room.
However, idle temps are not as important as load temps. You also fail to mention CPU.
https://linustechtips.com/topic/295690-dark-rock-3-temps/#findComment-4014307
I used intel extreme tuning ultility to stress test and it was around 75-80 i ran for 10min but when it was done and is idling at 5-1% cpu usage it stays 40-50 so should i redo the thermal paste? And what thermal paste do you recommend?
https://linustechtips.com/topic/295690-dark-rock-3-temps/#findComment-4015357
That is definetly bad mount. I before I just thought you had mixed low load and idle. I get 40C+ temps under low load of 10-15% while idle is 37C and full load 63C (max 67C).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/295690-dark-rock-3-temps/#findComment-4016872
