Ethernet not working.
Go to solution Solved by QueenDemetria,
You will need to download the driver from Asus's website if you haven't already.
Hi all,
About a month or so ago, I built my dream machine. I selected the Maximus Formula VII as my motherboard.
It came with a wifi adapter, but I didn't plan on using it. I tried using an ethernet connection instead, but when I plug it in windows doesn't recognize it in my networks.
All the lights on the IO light up around the ethernet port. I'm confused as heck.
What do I need to fix this? Driver? Or is my motherboard a dud?
Any feedback is much appreciated?
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/295555-ethernet-not-working/
Thanks!
https://linustechtips.com/topic/295555-ethernet-not-working/#findComment-4012660
