Sound poping
Go to solution Solved by Lolzious,
Wow this helps A LOT!!!  Anyways, you think i should RMA?
You're welcome I suppose xD
If it's uncomfortable or getting bad then yeah try contacting Newegg or Razer
So recently my brand new pair of Razer Kraken Chroma's have been making a popping noise when listening to stuff.  The sound will randomly go away for like 0.1 seconds then it will make a sort of cracking sound (for just like 0.1seconds and then it will continue like normal.  This may be a coincidence but this started happening right after I defragged my disk.  Do you think this is something on hardware or software?  If it is software how do I fix it.  If it is hardware should I contact newegg or Razer?
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/294798-sound-poping/
contact them ot should be your best bet
Okay
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/294798-sound-poping/#findComment-4002449
> Implying Corsair is better.
Corsair is love. Corsair is life.
Perhaps, but that doesn't mean they're and audio company.
For RGB gaming headsets, I have a hunch Corsair is the way to go.
I have rather more than a hunch that "RGB gaming" headsets are not the way to go, period.
Indeed, but if one is extremely interested in the concept, and they didn't mind paying more money to have flashy lights on a headset, Corsair would be the way to go.
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/294798-sound-poping/#findComment-4004108
Okay doing it now
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/294798-sound-poping/#findComment-4004204
