Do you have an OC applied?
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
I used to have O\C on, I restored to default!
What PSU do you have?
750 ocz
Try monitoring your PC for a while until it crashes, see if something is spiking
What exactly, Ima monitoring?
Use HWinfo to look at wattage voltage, pretty much all of your components. And if one of them spikes, there is your problem
Should I be stressting With aida64 while I monitor?
yeah, that or prime95
Ill keep you posted, thanks for your time
PM me if you need more help
http://s7.postimg.org/3sk4xlb6j/IMAG0706.jpg
Here's What I get after ~20 min of burning.. ? is this consider has a fluctuation?
So your PC didn't turn off in/after the stress test?
Anything Else I can try?
I don't really know at this point, try switching out components with spare ones maybe to see if something is faulty
