Why do you want to upgrade?
/some Z77 board
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/293776-motherboard-upgrade-help/#findComment-3988544
Mostly because I can't fit 4 RAM sticks in in my mobo due to my CPU cooler. And my budget is $100 to $135.
A new cpu cooler would be cheaper than a new motherboard; plus a new board likely won't even alleviate the issue.
PSU Tier List | CoC
https://linustechtips.com/topic/293776-motherboard-upgrade-help/#findComment-3988575
