im currently in the process of building a new rig for gaming and what not. I just need to know if the A10-5800k is able to be paired with a high end AMD GPU, will it perform well? mostly games like league of legends and i want to be able to stream using obs. I do have an old nvidia quadro i can stick in the new rig if that would help with the x264 encoding with obs
Why can't a Cleric/Priest/Bishop help a beginner KoC? Cause he's No-bless...When I post something, the thread dies.OR I'm incredibly good at giving informations,
OR I'm a thread killer.
Prolly both.
https://linustechtips.com/topic/293333-need-info-about-apus/
No, if paired anything higher than a R9 280 your cpu will bottleneck. It also makes no sense to get a APU if your getting a graphics card. APU are for people who can't afford a GPU as of right now, and if that's the case I'd get a A10-7850K instead
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3983334
I recommend to go with an i5, the CPU part of the APUs is not very good...
You are far better off by investing your money into something with more CPU horsepower, since you'll going to use a dedicated GPU.
If you still want to stick with FM2/FM2+, get the Athlon x4 860k (basically a 7850k with disabled GPU).
But still, even a locked i5 like the i5-4440 will do a much better job than an APU.
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3983376
I already know that. But if OP isn't purchasing a graphics until the upcoming months. Then a A10 is still the overall better choice. But if he is, then i'd get a 860K + 280, or i5 w/ a h81 board
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3983394
I assumed that he'll buy the CPU/Mobo at the same time as the GPU, so an iGPU is not necessary.
But if he should really buy the GPU later, maybe the iGPU of an i5 would do the job?
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3983423
The iGPU plays pretty well at 720p lol for counter strike, that's what i'm doing until I get a Galax 980
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3983429
i will never buy intel sure they get a little bit better performance but overpriced
Prolly both.
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3984204
yea i have decided on the amd Athlon x4 860k just gona use an old nvidia quadro fx 3500 until i can get a r9 270x
Prolly both.
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3984223
They aren't overprice... Once you put together a AMD FX and Intel build they equal the same price, and you get newer tech and better overall cpu for the same amount of money.
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3984225
Sounds like a plan. Have you picked out your motherboard?
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3984230
http://pcpartpicker.com/user/bureiden/saved/M6xWGX
Prolly both.
https://linustechtips.com/topic/293333-need-info-about-apus/#findComment-3984254
