I think thats alittle high on temps, I have my my 8320 on 1.5 with 4,8 GHZ and my idle is like 45. But I have a different cooler.
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/292438-fx-6300-oc-temps/#findComment-3971677
umm, Test at 4,5 and If it crashes at All I would begin to lower it and also watch the load temps and If it gets close to TJ max Begin to lower it
https://linustechtips.com/topic/292438-fx-6300-oc-temps/#findComment-3971719
Max temps And for your cpu it is 80C( i think), I would try to keep it at like 70 ish
https://linustechtips.com/topic/292438-fx-6300-oc-temps/#findComment-3971759
so i should stay at 4.5ghz? becouse its in the 70ish
the test has been running for an hr now and the max temp was 68 C
max recommended temperature from AMD is 65C, I would lower it or get some better cooling
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
https://linustechtips.com/topic/292438-fx-6300-oc-temps/#findComment-3972295
i have the fractal design define r4 case
Yes, but you should have 1 fan blowing in fresh air to the case, another out (if you only have 2 fans). Otherwise hot air is not going to leave the case readily.
— Grumpy old man
https://linustechtips.com/topic/292438-fx-6300-oc-temps/#findComment-3975545
