800$ Build Need help
Go to solution Solved by SImoHayha,
Hey I am new here and i came here because I really need a parts list for a computer im going to buy soon.
My budget is 800$ and this has to include Windows 8.1 and a decent monitor.
So after all that im guessing you have around 600$ to work on the computer.Might be less.
I dont know but I just need it to be very good at games.
I also will not overclock that much on it so i dont really need a cooler that isnt stock.\
There arent really any requirement besides the copy of windows and the monitor.
Also If its too much money I would rather have no ssd and put that money on other parts.
I will add one later on when I have more money to use.
Thank you and please help me. :D
here is a much more powerful build..
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($174.99 @ NCIX US)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($87.89 @ SuperBiiz)
Memory: Team Elite 8GB (1 x 8GB) DDR3-1600 Memory  ($60.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($53.97 @ OutletPC)
Video Card: Sapphire Radeon R9 270X 4GB Dual-X Video Card  ($164.99 @ Newegg)
Case: Cooler Master Elite 350 ATX Mid Tower Case w/500W Power Supply  ($54.99 @ SuperBiiz)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($88.98 @ OutletPC)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor  ($99.99 @ NCIX US)
Total: $786.78
Generated by PCPartPicker 2015-01-16 18:14 EST-0500
over the budget by 20$ but much more powerful
Base Total: $820.79   Mail-in Rebates: -$35.00   Shipping: $0.99   Total: $786.78
https://linustechtips.com/topic/292224-800-build-need-help/
Motherboard: MSI A78M-E35 Micro ATX FM2+ Motherboard  ($60.98 @ Newegg)
Video Card: MSI Radeon R9 270 2GB TWIN FROZR Video Card  ($173.98 @ Newegg)
Case: Cougar MX300 ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($42.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($122.98 @ Newegg)
Monitor: Asus VE228H 21.5" Monitor  ($138.98 @ Newegg)
Total: $813.85
Generated by PCPartPicker 2015-01-16 17:44 EST-0500
This one includes a cooler since AMD can be just a tad hotter, but its not worth intel on your budget. Also that r9 270 is a guaranteed 1080p/60fps on most titles. Mantle is a plus too, and you won't have to worry about games not working if you only had two cores.
ZerueLX11
Check me out! LTT Forum Profile!
https://linustechtips.com/topic/292224-800-build-need-help/#findComment-3969701
You can totally
go with intel
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/292224-800-build-need-help/#findComment-3969789
Total: $786.78
https://linustechtips.com/topic/292224-800-build-need-help/#findComment-3969937
Total: $786.78
Thank you and im sure i can find an extra 20 dollars.I am going to change the monitor to one a previous person suggested because it has hdmi and this will allow me to connect something else to my monitor with out need for a converter.I am also getting windows 8.1 just because its newer.Thanks for the build!
https://linustechtips.com/topic/292224-800-build-need-help/#findComment-3970032
