Problem With Multiple Monitors Plugged in
I recently bought an ASUS PB287Q 4K monitor which I love to pieces, but for some reason when I plug my 2 1080p monitors in as well, the framerate when I launch a game is abismal, even on loading the game. I bought a 970 with the monitor. Any ideas what it could be?
https://linustechtips.com/topic/291669-problem-with-multiple-monitors-plugged-in/
I'm only loading the game on the 4k monitor, just for some reason having the two 1080p monitors plugged in makes it run awfully, it didn't actually happen the first time, only after I restarted.
use quotes
try restarting again?
if not you may need a second car for those 2 monitors
get a second 970 and plug the 2 monitors in that one xD? or don't play across 3 screens at once
it doesn't work that way lol
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
which part
(even with sli)?
I believe you have to plug all the monitors in the top gpu regardless of multi-gpu solutions. Or maybe I'm wrong and my whole life has been a lie O.o
Main Rig
Phone
http://www.nvidia.in/object/sli-technology-multimonitor-in.html
not with sli
if you don't sli them
then you can
