Help i dont get it!
Go to solution Solved by LeaTheTechWoman,
The Titan is based on nVidia's GK110 chip with the Kepler architecture. You can't compare specs of the GK110 and the GTX980 which is based on nVidia's new Maxwell architecture with the performance GM204 chip 1 to 1.
Maxwell has a new way more efficient architecture and is a huge benefit in terms of power consumption, and OC ability. The factor from Kepler Cuda to Maxwell Cuda is 1.4. So that  means the Maxwell GM204 with its 2048 M Cuda is in Kepler's world 2048 x 1.4.
Another important thing to understand is, that the Maxwell gen has a different L2 cache of 2 MB. Kepler 104 has 512bit and Kepler 110 has 1.5MB. That means the card doesn't struggle with memory bandwidth so fast in higher resolutions. Keep in mind a Titan Black still has 6GB GDDR5 VRAM buffer and will not struggle either due to its 384bit memory interface BUT the GTX780Ti which is pretty much the same just doesn't have thge full unlocked double precision and just 3GB GDDR5 VRAM struggles to death in 4K once the memory buffer is full.
The Titan Black is a card for semi professional content creators. Like written before it has the full double precision enabled and the 6GB GDDR5 VRAM ensure that content creators don't run into bottlenecks VRAM wise.
Gaming wise I'd always buy nowadays a GTX980 over any Titan Black because especially the GTX980s are made for resolutions above 1080p and Kepler was originally designed for 1080p and the Titan Black is way more expensive and not as fast as the GTX980.
wow
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/291392-help-i-dont-get-it/#findComment-3957159
Because Nvidia.
But really though, the 980 is a newer gen card compared to the slightly older architecture of the Titan Black.
Titan Black is way more expensive since it's geared towards VERY serious content creators (not just gamers) who have the money.
GTX 980 is geared more towards the masses of regular hardcore PC gamers.
Slightly off topic: GTX 970 is better in terms of price to performance though. My opinion.
Laptop - Asus TUF FX504GM
i7 8750H | 24GB DDR4 | GTX 1060 6GB | 128GB NVMe SSD | 1TB HDD
Peripherals
Logitech G102 Prodigy | Nubwo N12
https://linustechtips.com/topic/291392-help-i-dont-get-it/#findComment-3957190
Never use GPUBoss for comparisons.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/291392-help-i-dont-get-it/#findComment-3957198
cause titan black has a higher specs than the 980
true
I usually use game-debate but i was in a rush.
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/291392-help-i-dont-get-it/#findComment-3957373
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/291392-help-i-dont-get-it/#findComment-3957477
wow
https://linustechtips.com/topic/291392-help-i-dont-get-it/#findComment-3957933
