I am considering hosting a four person LAN tournament, just me and my friends. One problem: I have no clue how. Lets assume we are playing DotA 2. How would I go about setting up? I know nothing about networks. No terminology, nothing.
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/290615-lan/
If you're hosting, make sure you have one or more of the following (just in case):
Generic power cables
Ethernet cables
Backup switch
Backup surge protector/powerbar(s)
Mousepad
Power extension cables (industrial quality)
Knowledge of how to use your circuit breaker
GW2: Vettexl.9726
https://linustechtips.com/topic/290615-lan/#findComment-3946281
https://linustechtips.com/topic/290615-lan/#findComment-3949011
just get a small switch with enough ports for the machines with at least one spare, then get a small home router (dosent have to be connected to the internet.) then plug that into the switch.
plug all of the machines into the switch and the router should give everyone an IP
Bingo all done
https://linustechtips.com/topic/290615-lan/#findComment-3950284
Bingo all done
so I just plug the server and all the playing machines into the router via Ethernet, and from there just proceed as I would normally to set up a server for DotA and/or Minecraft?
https://linustechtips.com/topic/290615-lan/#findComment-3953445
