Max Fan Header Amp
Go to solution Solved by Lolzious,
I don't think you would run in to any problems :)
I'm currently building on a M-ITX bord and I have a AIO cooler and 2 case fans. However I only have 2 headers. Can I split for 3 fans on one header?
I have heard 1 amp is the max you should go on a header but I should check my mobo. I couldn't find anything on my Asrock H97-M-ITX/ac. Is 1 amp a general industry standard?
Molex is not really a good option plus I would have to buy some cords anyways so a spliter would be cheaper and less of a burden in my small case.
I figure I leave the AIO pump to have one header and spit the other one. The 3 fans would max at .86 amps.
Fans are C.M. Blade Master 2 120mm 1 80mm
I know speed rage is different for the 80 (800-3000 rather than 600-2000). Would this be a problem on its own?
I'm not looking to control each fan and noise isn't a factor so I'm skipping a fan controller.
Thanks!
https://linustechtips.com/topic/289938-max-fan-header-amp/
  • 2 weeks later...
