Does anyone know were I can get spare parts for my NZXT Phantom 820 ?
One of my USB 2.0 ports has got damage from a cat and a USB stick ( cat hit stick, Stick Damage and broke the USB port ). I have tried NZXT but no feed back.
Or should try and fix it myself and if so how would u got about this ?
Thank Mark
post-2871-0-02824100-1372004308_thumb.jp
https://linustechtips.com/topic/28982-spare-parts/
Do you need all of them ports, im sure you can make do with the other ones, put a bit of tape over the broken one so you dont try to plug something in there and break that as well.
Listen if you care.
https://linustechtips.com/topic/28982-spare-parts/#findComment-371609
