Can't find graphical drivers , found some but games still run poorly
Laptop model VPCEB11FX (sony vaio)
Windows 8.1 64bit
Everything was ok in Windows 7 but i decided to install w8 cuz my computer was full of bloatware
Update : thanks for your suggestions but i have tried them already , guess the only option is installin w7 again
https://linustechtips.com/topic/289339-laptop-drivers-problem/
Windows 8.1 64bit
have you tried windows update?
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/289339-laptop-drivers-problem/#findComment-3928295
Windows 8.1 64bit
If that model is old and does not have Win 8 drivers from Sony, then you kind of screwed up. You might need to install 7 again, but you can do so without the bloatware.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/289339-laptop-drivers-problem/#findComment-3928329
Try downloading the Intel HD graphics driver, but unfortunately Sony doesn't support windows 8 on that laptop, windows 7/XP only.
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/289339-laptop-drivers-problem/#findComment-3929454
Just download the windows 7 driver, once you've downloaded it, right click on the installer and click on "Properties" and go to the "Compatibility" tab, and set the driver compatibility for Windows 7, then click "Apply" and "Ok", then install the driver as normal.
There is no difference between Windows 7 drivers and Windows 8 drivers, the only difference is is that older drivers don't recognise the Windows version string and won't install because it thinks it's not compatible, even though it is.
CPU: Core i5 2500K @ 4.5GHz | MB: Gigabyte Z68XP-UD3P | RAM: 16GB Kingston HyperX @ 1866MHz | GPU: XFX DD R9 390 | Case: Fractal Design Define S | Storage: 500GB Samsung 850 EVO + WD Caviar Blue 500GB | PSU: Corsair RM650x | Soundcard: Creative Soundblaster X-Fi Titanium
Click here to help feed our lasses Pokemon
https://linustechtips.com/topic/289339-laptop-drivers-problem/#findComment-3929955
https://downloadcenter.intel.com/
There you should find the diver you need.
If you can't find it manualy, just go for the auto detect utility and you should be fine.
Go for Win7 Driver if you cant find the right ones for Win8.
All drivers for Win7 and 8 are mostly the same anyway.
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems during CPU installation." -Linus
https://linustechtips.com/topic/289339-laptop-drivers-problem/#findComment-3931979
