Hi guys, I'm doing a build and I can't decide on a case, and I want some opinions.
Which case is better? the switch or the elysium?
Build:    Maximus VI Formula (assuming its EATX)
             XFX 750W Proseries
             RX360
             D5 Vario Pump with front bay reservoir
Basically the parts included above are those that would affect which case I choose. Also, I'm really hooked on the idea of putting a 360mm rad in the top. I'm not really a fan of the front or bottom mounted rad.
Also, for the switch, what do you guys think of placing the rad here? : 35c49517_switch810top.png
As in placing the rad in the top compartment and taking the panel off?
Aside from that, I heard the ridges on the sides of the bays don't allow the dual bay reservoir to be installed. can anyone confirm this?
also, what do you guys think of the phantom 630? (I was considering it, but I wasn't sure if the front panel would allow me to install a fan controller [fc5v2] and the small window was also quite unappealing. anyone knows of a window mod for the 630?)
https://linustechtips.com/topic/28928-nzxt-switch-810-vs-elysium/
