I finally have enough money to start my own computer build but I need help picking the components. I'm planning to buy in 1-2 weeks, around the 21 Jan
PC Builds
- Budget: $1,800 USD
- Zip Code or Location: Fairbanks, AK USA
- Specific Use: Gaming with light 3D animation
- Any preferred components?: SSD Boot drive
- Any spare parts you can re-use?: 2x 1TB Drives. Anything possible, see below
- Overclocking your processor?: Preferably
- Need an Operating System?: If possible I would like to transfer my current OS to the new drive
- Need a Monitor? / Mouse? / Keyboard?:If I need to upgrade to Windows 8.1 I will need a touch screen monitor. I would like a LED back lit mechanical keyboard
- Need a Wireless Card or Adapter?: No
- Need Another Component? (Specify): At least one HDMI port on the graphics card as I use a TV for one of my monitors. I would like to water cool the system, whether its just the CPU or whole system.
Other Useful Info
- Preferred Case Features (Ex: Color, Side Window, Flashy): preferably, black or red but not very important because I plan to upgrade to a custom case in 6-9 months
- Number of Monitors: Normally one but occasionally 2
- Other Info?:
I would like to re-use as much as possible to save on costs but I am willing to dump it all if necessary.
On my current system I have
Motherboard: Asus sabertooth 990fx
RAM: 2x Corsair Vengeance 8gb 1600mhz
         2x g.skill Ares 8gb 1600khz ddr3
(Note: my current system only recognizes 12 GB of ram)
Graphics: GT430
CPU: AMD FX-6200
PSU: 600 watt
https://linustechtips.com/topic/287730-help-with-my-first-build/
Reuse: motherboard, memory, psu, hdd.
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($168.89 @ OutletPC)
CPU Cooler: Swiftech H220-X 55.0 CFM Liquid CPU Cooler  ($149.99 @ Micro Center)
Motherboard: Asus Sabertooth 990FX ATX AM3+ Motherboard  (Purchased For $0.00)
Storage: Crucial M550 256GB 2.5" Solid State Drive  ($90.98 @ Newegg)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($347.99 @ Directron)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($108.99 @ SuperBiiz)
Total: $866.84
Generated by PCPartPicker 2015-01-09 20:47 EST-0500
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910438
I would go the Intel route. Sell your AM3+ board.
What make/model psu do you have ?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($218.98 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($116.75 @ OutletPC)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($329.00 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Newegg)
Total: $898.46
Generated by PCPartPicker 2015-01-09 21:17 EST-0500
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910580
Lee32uk
I have a Corsair CX600. For the CPU cooler could i substitute a water cooling system? Thats going to be a big part of my custom case so I would like to get it now rather than swap means of cooling later.
Brob.
Thank you for the recommendations.
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910651
Lee32uk
Brob.
Yes you can go with a sealed water cooler such as the H100i, H110 etc. The one in Brob's spec is an expandable one, so you can add to it. It depends on what you want.
I would still say that Intel is a better choice. You will get stronger performance in gaming over the fx-8350. Even though the i5 4690K has fewer cores, they are stronger than the AMD.
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910673
Because it's very hard to troubleshoot memory issues, I decided to go safe and just buy a new kit. Overall, this build is flexible, you can remove the second 970 if you don't feel like you need all that power and swap it for more RAM.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($318.99 @ SuperBiiz)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($104.99 @ Newegg)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($138.98 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($130.98 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($78.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card (2-Way SLI)  ($329.00 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($93.99 @ SuperBiiz)
Case Fan: Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM 120mm  Fans  ($27.98 @ OutletPC)
Keyboard: Cooler Master CM Storm Quick Fire TK Wired Gaming Keyboard  ($83.97 @ OutletPC)
Total: $1841.85
Generated by PCPartPicker 2015-01-09 21:40 EST-0500
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910686
Lee32uk
Thank you
I've never used more than one graphics card, how much more power would it give me? I normally do RTS games like Starcraft but would like to get into using my PC for games i would normally play on console. Would the second 970 be needed for that?
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910742
Lee32uk
Thank you
If you have a 144Hz monitor or a 1440p monitor, yes, if not, I don't think so
https://linustechtips.com/topic/287730-help-with-my-first-build/#findComment-3910799
