DD-WRT is supported and I think Tomato is too so it's worth it in my opinion. I have the RT-N16 and it runs great. It was a huge improvement from my WRT54G.
Install Gentoo GNU/Linux | "You have been placed on moderator queue. This means that all content you submit will need to be approved by a moderator before it will be shown." | top LEL
Build specs: Corsair 540, i7 2600K @ 4.2Ghz, Asrock z77 extreme4, 16gb DDR3 @1866, 2 x 1TB, GTX 560 ti
Monitors: Asus VG236H, Dell U2713HM Headphones: Koss PortaPro, DT 770 80ohm, AT-AD700 | Steam profile
I have the ASUS RT-AC66U and it's pretty great.  I haven't used any AC devices on it yet, but N speeds are fine.  There are options galore to to tweak in the settings if that's your thing.  I'd recommend it.
System: Intel Core i5 3570K OC@ 4.4GHz | Cooler Master Hyper N520 | ASUS Maximus V Gene | 8GB Mushkin 1866MHz RAM | MSI R7970 Lightning | Seasonic X-850 | Fractal Design Define R4 White Windowed Edition
Peripherals: BenQ XL2420T 1920x1080@120Hz | Filco Majestouch 2 Tenkeyless (with Cherry MX Browns) Mechanical Keyboard | Razer DeathAdder Left-handed Edition Mouse | ODAC to various things
