USB Headset Electrical Noise.
So I have just got the ROCCAT Kave 5.1 second hand.
It uses green, orange, black and pink 3.5mm for I/O and one USB 2.0 for power and volume control.
I'm using the rear I/O of my ASRock 990FX Extreme3, and have never had electrical noise through previous headsets.
To troubleshoot this, I unplugged each 3.5mm jack, one by one until no jacks were plugged in.
I still had the electrical noise, and only the USB was plugged in.
How do I fix electrical noise on USB?
https://linustechtips.com/topic/286697-usb-headset-electrical-noise/
It was given to me from a friend, but that wasn't why they got rid of it.
The headset is so heavy, that for extended use, it gives shocking headaches around the headband.
Edit: But yes, I agree. It's probably defective, I would expect ROCCAT would have fairly high standards.
