Problems with Shadowplay.
Go to solution Solved by PassionFruit,
Okay, it has been fixed. The reason was that I had to get the Media pack for Windows because my 8.1 N doesn't come with one. @Go_On_Shadow
Hi.
I know this is a common issue that people have but I don't know how to fix it.
I'm not able to record my games in Shadowplay, when I press the record button the status indicator has a red line over it. I tried re-opening an re-installing Shadowplay with no luck. I also have tried recording in different games such as CS:GO and Battlefield 3.
Thanks
Potatoes are good for your nostrils.
https://linustechtips.com/topic/286555-problems-with-shadowplay/
Hi.
Thanks
My retarded cousin at work again.
GODDAMINIT SHADOWPLAY
(referring to the name of shadowplay itself, read my name)
I just felt like I needed somthing here
https://linustechtips.com/topic/286555-problems-with-shadowplay/#findComment-3890704
