Sapphire R7-260X Problem
Solved by dragoon20005,
your driver for the GPU was not installed correctly the first time
do not use the driver in the CD, coz it always outdated
use Display Driver Uninstall to remove the current driver
boot to safe mode with networking by pressing on the F8 key after the BIOS splash screen
install the AMD drivers again
and restart.
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3 -
8
