G430 Headset Replacement
Go to solution Solved by Interfectorem,
Cloud.
A cluster of water vapor can be used as a headset? /s
My G430's from Logitech have been cracked for some time now, and one of the ear cups finally fell off today.
I have Jerry Rigged them back together with some electrical tape, but i am going to need to replace them soon.
I need some advice on what to buy.  I don't want to spend much more than $100, and i wouldn't mind buying an attachable mic if that is the best route.
Thanks  :D
Kingston HyperX Cloud
Thanks  :D
 post-123388-0-15420500-1420409884_thumb.
https://linustechtips.com/topic/284483-g430-headset-replacement/
Cloud.
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3861578
Cloud.
Thanks  :D
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3861593
Oh my f.. oh my.  I went through 4 G930s and the same thing happened.  For all that is holy, do not buy Logitech series headsets with that design.
That Kingson headset is one of the better ones.
Corsair Vengeance 1400 or w/e is alright.. decent hinge design COUGH LOGITECH.  Sound quality leaves something to be desired.
edit:
To be clear, it was through RMAs, I'm not daft enough to buy 4 in a row
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3861620
Thank you guys for the help!  I will be getting The HyperX Cloud II when they come out in fubuary.
My friend got tired of his 430's and went out and got Hyper X clouds. He very much enjoys them. So I think you may have a similar experience.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3863059
Ah I see, but just as a disclaimer, it says "virtual 7.1 surround sound" but we only have two ears right? 7.1 surround sound is just a marketing gimmick,we WON'T really find a adequate difference between regular stereo and 7.1. I am seriously telling you, just listen to me and save yourself some gud monies to buy other peripherals...
Here is a proof on why. If you have any headphones or earbuds, use your best ones and play this video which would prove why you can still hear as if it was "7.1 surround sound".
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3864477
yeah thanks, but the only reason i am getting the 2's is for the all black model because my set up is all black and blue
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3883031
This is true for headphones, as you have the physical drivers not even an inch from your ears.  However 7.1 is indeed relevant when we're talking home theater systems, as the speakers are a bit further away from you, so one can find a noticeable difference there.
Just get a quality pair of stereo headphones, set your speaker setup to "Stereo," then let the game's audio engine do the rest.
[witty signature]
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3883137
Yea, for like a home theater that is definitely true because there is actually will be depth in the sound rather than the sound just coming from only two sides. I have surround in my home theater which does actually make a difference rather than just regular headphones which companies do to steal your money.
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3884151
Ah okay, I mean that is nice to to match up with other things too. I hope it is good because even if there is or isn't surround sound, the original HyperX Cloud which is what I have is already a really great headset for the $100 and below price range as it even competes with some higher end gaming headsets. Hope it is good too! :] (Most likely will!)
https://linustechtips.com/topic/284483-g430-headset-replacement/#findComment-3884203
